Malingos
Ok I am in need of some help here, I’m not sure what I’m doing wrong. I am trying to set the valves on this iveco 6.7 engine and not coming out right. Ok so I barred the engine over and set timing pin and checked all marks on gears and all in place, set it at TDC and began adjustment but when I rotate 360degrees to adjust the rest, I am not able to do so because exhaust 2 and intake 3 are not loose. If I turn it to loosen them up then it’s all out of wack. I know I’m screwing up somewhere...Help please
