New 2020 772 GP Deere
Cat 140M AWD
Montrose S.D
Motor grader operator
Took delivery of my new 772GP yesterday here are a few pictures I took of it got the wing taken off and put a good 8 hours on it today I’m liking it so far I also am one of the first in my state to have the new logo design on this grader I like it think it looks really sharp.2F7E5779-54C4-4C38-8ADC-D9FC76C9BEF3.jpegA4D344DB-C6B2-4ECE-958F-681B382EC83F.jpeg14E0F738-E112-4823-92A3-7B2058549D29.jpeg
guest
Texas
Nice machine see you getting blade shiny. I started on a Deere 570A ended with Volvo tried to suggest Deere to them but you know how gov low bid works. Enjoy it
ovrszd
Missouri
Retired Army
Thanks for starting this thread. Keep updating as you put some hours on it. Curious to hear of any problems you have.
I too like the new striping and logo. At a glance didn't see any other exterior changes.
Can you shift your table to the bank position on the right side with that extension?
16ft total moldboard?
I'm at 400hrs on our 672G. I've been cleaning out drainage ditches for the past week or so. Really like the all wheel drive.
What brand tires are you running?
Cat 140M AWD
Montrose S.D
Will definitely keep updating as I put hours on the machine and yes I have a 16ft moldboard and I can also use the bank position on the right side with the extension and these are Michelin gls2 tires on this machine I wish it would have the snow plus tires going to miss them in winter for snow plowing.
ovrszd
Missouri
Retired Army
I've always had Michelins. This time we got Bridgestones. I don't see much difference. Time will tell on longevity. I never had problems with the Michelins.
I pushed two small snows without chains. Had to use AWD in the steep hill portions.
Cat 140M AWD
Montrose S.D
The AWD definitely helps in the snow with the snow plus tires I hardly had to use the AWD but I’m sure I will need it with these tires
Cat 140M AWD
Montrose S.D
Well I operated for 2 hrs got out to look over the machine and I noticed it was dripping oil out of the drain tube checked the drain valve it was closed so called dealer and they had to come out and installed a new drain valve found the seal bad on the drain valve lucky I caught it also have a couple of fault codes up on the monitor for the left and right reverse lights mechanic didn’t tell me much other then he’d look in to it.
ovrszd
Missouri
Retired Army
My engine oil drain tube always has oil/dust on the end of it. Won't leave a puddle on the concrete or anything, but is seeping.
In regards to the fault codes. I'm afraid to ask, but are they these codes?
TCU 516773.06 TRANSMISSION RIGHT REV LAMP CIRCUIT FAULT
TCU 516770.06 TRANSMISSION LEFT REV LAMP CIRCUIT FAULT
I've had this code problem since new. Still codes periodically. I submitted my Deere Customer Satisfaction Survey and outlined this problem that's ongoing. No response yet from Deere.
To address mine they replaced the shifter and both rear lights. I think it's a problem in the Computer programming in the machine. With LED lights there is a slight hesitation before they come on.
I think the computer diags the shift into reverse too quickly. One of the diags is to test for load on the reverse light circuit. I think it detects no load before the lights have a chance to come on. Throws the code.
The most aggravating part is once it codes it won't reset without shutting the machine off and restarting. Until it resets you have no reverse lights......
Deere blamed me for shifting to reverse too quickly. How the hell are you supposed to slow that process down?? The shifter toggles to Forward or Reverse, there's no neutral in the middle........ That one really Pi**ed me off!!!! Tried to blame their problem on me. Our machine threw this code the first time while it was still at the factory. Threw it the second time while it was being prepped at the dealer. Code was active when they backed it off the trailer at delivery to me.....
Cat 140M AWD
Montrose S.D
I have the same fault codes as you do on your machine haven’t heard anything back from my dealer yet will let you know if they figure anything out.
ovrszd
Missouri
Retired Army
I was afraid you were going to say that......
If we ever get a fix I'll pass it on to you also. I've raised the issue to Deere level so maybe......
How about your delay shutdown? Does it work?
LN Pipeline
Montana, USA
I’ve had to add these to some LEDs to make them work properly on a newer Ford pickup.
Computer didn’t detect a load from the LEDs and shut down the circuit.
I would think your machine would be designed to function properly with them if they came from the factory. But it would be a cheap experiment to install these and see if it solves your problem.
Some of my LEDs functioned properly, some needed these resistors. I had a 12V system, so you may need a different resistance.
ovrszd
Missouri
Retired Army
Yeah my Son who's a mechanic suggested using those. I agree. But until Deere is done doing warranty work I'm not going to try one. Not going to give Deere a reason to stop trying to fix the problem on their dime.
Thanks for the suggestion!!!
Cat 140M AWD
Montrose S.D
My delay shutdown has not worked yet and ik it should of my dealer knows about that also ik on my cat machine the delay shutdown works great.
ovrszd
Missouri
Retired Army
On our 770G pre-DEF machine it worked great too. It took me awhile to reteach myself to not chuck it in park and hit the stop button. That issue has also been raised to Deere level. I'm pretty sure now I'm being ignored by the dealer waiting on my 1st year free warranty repair coverage to expire. Then they'll want to start charging me for trips to work on the machine.
Cat 140M AWD
Montrose S.D
Well here is the latest update on my new machine currently have 45 hours on it was operating it yesterday and got a low coolant warning on my monitor so stopped checked the tank and was definitely below the add couldn’t see any leaks so went back to the shop and parked it my dealer is coming out tomorrow morning to see what they can figure out will report back what they find.
ovrszd
Missouri
Retired Army
Every new grader we've purchased has had the coolant level right at the low mark. A couple have tripped the warning light until I fill closer to the full mark.
Hopefully yours is something like that rather than a leak.
I'm at 500hrs. Had another fluid leak couple days ago at the AWD hydraulic junction box at the front of the main frame. Another leaky O-ring where the test ports fasten to the box. That's the third leak on that junction box.
Still coding reverse lights but rarely now. Maybe once every 25hrs. Still no Delay Shutdown. Haven't heard from Deere after sending in my customer satisfaction form listing my problems 3 months ago.
Cat 140M AWD
Montrose S.D
Well my dealer come out and found a bad hose on the thermostat that was leaking got it replaced and I’m back in business now have 70 hours on the machine and everything seems good still get the reverse light codes periodically as you do.
ovrszd
Missouri
Retired Army
Still no Delay Shutdown?
I've noticed my reverse lights don't code as often. Actually haven't coded in about 30 hours. I'm wondering if I got an update thru JDLink that solved the problem? I'll keep you posted.
Cat 140M AWD
Montrose S.D
Still no delay shutdown on my machine and I haven’t gotten a reverse light code in the last 20 hours.
ovrszd
Missouri
Retired Army
Wondering if Deere fixed the light issue with an update. You'd think they would notify everyone when they do that........
