Cat d5m ecm
Tyler d4c
Salix Pa
6as prefix I have all 3 140 blues wires have voltage 2 202 wires have ground have no voltage between can hi can lo.
Is there any more test I can do to prove it to be a bad ecm. Cat et does not find the ecm. Thanks for the help.
Are you saying that pressing & holding the switch (2) to the right of the display window for at least 1 second doesn't scroll the display..?
At the first press it should scroll from hourmeter to engine RPM, then at the 2nd press to Diagnostic Codes.
Tyler d4c
Salix Pa
Must not have been holding it long enough I got
030
0096.03
0271.05
To display in that order
030.0096.03 is the fuel level sensor
030.0271.05 is the Action Alarm for the Monitor. I take it the alarm doesn't sound as part of the test when you key on.?
Did these two Codes just continously scroll or after the 2nd one did you get something like "END"..?
What is the tractor doing, or not doing, as the case may be..?
Tyler d4c
Salix Pa
Yes those codes scroll though and say end and just keep doing it there is no auditable alarm the machine will not move it has no transmission function whatsoever.
Mark250
victoria,Australia
heavy equipment technician
Hi I would connect ET directly to the ECM with something like this before I would condemn the ECM
Good idea Mark.
Tyler, the only pair of twisted cables you will need (out of the two pairs shown) are the ones for the Cat Datalink. The other pair will be for the ATA which is used for Winflash and will only work with a dealer verison of ET.
if you have a DT connector pin extraction tool you will be able to remove the relevant pins in the ECM connector(s) and install the ones from the bypass harness.
The diagram below is a design that I think will workin your application. You'll need to double-check the Pin Numbers on the 40-pin transmission ECM connector on the tractor.
The Pin Letters of the 9-pin Comms Adapter connector on the RH side will remain the same.
Tyler d4c
Salix Pa
I decided to pull the ecm off and I gave it a shake and I heard parts in it so I think to my self I bet I can fix it. I was wrong had water in it.
Tyler d4c
Salix Pa
Do you have any more information on your set up I decided to get a plug and ecm out of a junk machine I have just to play around with. It has 4 wires on it two data links and positive and a negative. What are your other two twisted pairs for? Thanks
See post #9 above. The other twisted pair is for the ATA Datalink that is only used for Winflash (software uploading) on Dealer versions of ET.
For diagnostics only the Cat Datalink - and + wires that go to Pins 3 & 9 respecitvely on the 40-pin connector on the ECM are required. Make sure not to connect them "backwards".
Tyler d4c
Salix Pa
You only need the Cat Datalink + and - that go to Pins 3 & 9 on the 40-pin connector on the ECM.
Ok I missed it I do have to power up the ECM to see it correct.
Mark250
victoria,Australia
Generally you only need one power and ground for basic hook up as the pos+ pins are connected together internally and the neg - pins the same.
Tyler d4c
Salix Pa
I've messed with it a few hours tonight on a c12 truck engine ecm but have yet to get it to work. It may also be bad as it is full of engine oil. I should have taken a photo of the error I keep getting.
Mark250
victoria,Australia
Hi, don't use the pin outs that Nige posted above on the C12 ECM
your Machine ECM is a MAC ECM and uses the 40 pin connectors
your C12 ECM is probably an A3 or A4 either one will have a 70 pin connector
THEY ARE COMPLETLEY DIFFERENT IN THERE PIN CONFIGURATION AND YOU COULD DAMAGE THE ECM
I posted a thread a fair while ago above different ECM's I will see if I can find it
