partsandservice
I was only making suggestion of common extended/ no start conditions thatth have experienced with the C-7. By the way I was speaking oil injection pressure not fuel pressure. As mentioned earlier , do you hear the grid heater solonoid activating When key on, it will activate with out going into the start position. It is simple diagnosis as it is no different than an old Ford starter solonoid. Power to the solonoid is provided through a breaker, activation of the solonoid(exciter) comes from the ecu.
