When it absolutely positively has to be pintle...
crane operator
sw missouri
But you better have stock in a tire company. On 16.5's no less.
I don't know what they were hauling, I'm guessing dozer or track loader, but I don't know you would keep the tires on it.
https://www.purplewave.com/auction/191114/item/FJ9796/1999-Butler-Trailers-Equip._Trailer-Kansas
I wouldn't want to have that coming from the other direction on a rainy day in West Virginia! If it was loaded not sure the tow vehicle would be able to make the curve!
fast_st
Mass
IT systems admin
Maybe it has some steering tag axles, the spacing seems weird
By what I can make out the very front seems to be alone as if added in as well the absolute rear. Have seen this set up with Three axles with equalizers but the five is unmistakably a BIG error in judgement. Cut away the Front and absolute Rear, get the 16.5s OFF this go to 16s trailer rated G Series or something at least as severe duty. Use as was intended for Median loads and likely be a Nice Little Trailer. The Komatsu sitting well out of the Frontal shot photo gives an idea what was being towed On this. Was probably lifting the tow vehicle Off the ground when loading and then crushing it into the dirt once tried for tongue weight, again BAD Decisions made.
That front axle lifts slightly that's why it's air ride on the front only, you can see the lift bag in the one photo. The worst part is all the side loading of the second and fifth axle.
Set-ups like that don't take long before the wheel seals start leaking if not set at zero end play on the wheel bearings.
fast_st
Mass
IT systems admin
Are the raised ribs to keep your dozer from sliding off the side a second time? Would think a couple inboard stake pockets with removable rails would be better, I have a feeling it started out as a triple axle.
Crummy
I'm scratching my head on how a guy would get any weight on without burying those front couple of little 10k axles?
I wonder what the tare is, looks heavy.
