When it absolutely positively has to be pintle...
Discussion in 'Trailers' started by crane operator, Nov 5, 2019.
  1. crane operator
    crane operator Senior Member
    Mar 27, 2009
    3,884
    sw missouri
    nomorelawns, WRA, pushbroom and 3 others like this.
  2. Junkyard
    Junkyard Senior Member
    Jun 5, 2016
    3,004
    Field Mechanic
    Claremore, OK
    Man that thing would scrub terrible!
  3. petepilot
    petepilot Senior Member
    Jul 7, 2018
    854
    central shenandoah valley va,
    better have the power unit heavier than the loaded trlr.if you want to git it around a corner
  4. DMiller
    DMiller Senior Member
    Feb 22, 2010
    6,454
    Retired
    I can see that side wall rolling tires completely off in hard turns with any weight on it, what were they thinking???
  5. kshansen
    kshansen Senior Member
    Mar 11, 2012
    7,573
    Central New York, USA
    I wouldn't want to have that coming from the other direction on a rainy day in West Virginia! If it was loaded not sure the tow vehicle would be able to make the curve!
    DMiller likes this.
  6. doublewide
    doublewide Senior Member
    May 31, 2015
    289
    MA
    Can you even get a 16.5" trailer tire in load range G or H? Only thing I've been able to find is load range E in light truck tires.....
    pushbroom and DMiller like this.
  7. fast_st
    fast_st Senior Member
    Dec 1, 2010
    1,273
    IT systems admin
    Mass
    the obvious answer is Kansas
    kshansen and DMiller like this.
  8. kshansen
    Mar 11, 2012
    7,573
    Yea, but even in Kansas one must need to turn around once you get to the end of the trip. But I guess if you're smart you could turn around then reload to come home!
    DMiller likes this.
  9. lumberjack
    lumberjack Senior Member
    Dec 25, 2011
    1,025
    Columbus, MS
    I wanna get a picture of it behind my F150, towing a 320.
  10. fast_st
    Dec 1, 2010
    1,273
    IT systems admin
    Mass
    Maybe it has some steering tag axles, the spacing seems weird
    DMiller likes this.
  11. Mother Deuce
    Mother Deuce Senior Member
    Jul 17, 2016
    1,072
    New England
    It looks nearly pristine. It was not used much.
    DMiller likes this.
  12. Tags
    Tags Senior Member
    Feb 19, 2012
    816
    Connecticut
    It probably wasn’t used much because once they brought it into the yard to park it they couldn’t turn it around without all the tires popping off the beads....
    Spud_Monkey, WRA, Ronsii and 2 others like this.
  13. DMiller
    Feb 22, 2010
    6,454
    Retired
    By what I can make out the very front seems to be alone as if added in as well the absolute rear. Have seen this set up with Three axles with equalizers but the five is unmistakably a BIG error in judgement. Cut away the Front and absolute Rear, get the 16.5s OFF this go to 16s trailer rated G Series or something at least as severe duty. Use as was intended for Median loads and likely be a Nice Little Trailer. The Komatsu sitting well out of the Frontal shot photo gives an idea what was being towed On this. Was probably lifting the tow vehicle Off the ground when loading and then crushing it into the dirt once tried for tongue weight, again BAD Decisions made.
  14. Truck Shop
    Truck Shop Senior Member
    Dec 8, 2015
    3,225
    SE Washington St
    That front axle lifts slightly that's why it's air ride on the front only, you can see the lift bag in the one photo. The worst part is all the side loading of the second and fifth axle.
    Set-ups like that don't take long before the wheel seals start leaking if not set at zero end play on the wheel bearings.
    DMiller likes this.
  15. hvy 1ton
    hvy 1ton Senior Member
    Jul 24, 2006
    1,642
    Lawrence, KS
    Obligatory post about Kansas being the 7th flattest state and every state being flatter than a pancake.
    DMiller likes this.
  16. crane operator
    Mar 27, 2009
    3,884
    sw missouri
    At least you're not sensitive about it.:)
    CM1995, DB2, DMiller and 1 other person like this.
  17. Ronsii
    Ronsii Senior Member
    Jun 26, 2011
    2,456
    s/e Heavy equipment operator
    Western Washington
    I was gonna make a kansas joke... but seeing as you reside there I'll hold my tongue... :oops:
    DMiller likes this.
  18. 92U 3406
    92U 3406 Senior Member
    Jan 3, 2017
    1,185
    Professional Wrench Spinner
    Canuckistan
    What in the crystal meth is that thing?
  19. fast_st
    Dec 1, 2010
    1,273
    IT systems admin
    Mass
    Are the raised ribs to keep your dozer from sliding off the side a second time? Would think a couple inboard stake pockets with removable rails would be better, I have a feeling it started out as a triple axle.
    DMiller likes this.
  20. Crummy
    Crummy Senior Member
    Jul 9, 2017
    517
    Idaho
    I'm scratching my head on how a guy would get any weight on without burying those front couple of little 10k axles?
    I wonder what the tare is, looks heavy.
    DMiller likes this.
