Welder Dave, you know you are making the biggest deal out of nothing. Seems to be a thing with you.
I've had my fill of trying to help you.
What exactly does "supposed to be" mean? Something to back up that SN oil would replace SE oil used in hydrostatic transmission would go a lot further than supposed to be. Perhaps you can explain why Bobcat who also specified 10W-30 oil for years stopped recommending it after 2006? Maybe something to do with the new additives? Also most AG tractors aren't running 4000 PSI hydraulics and tractor fluid has been around for over 50 years. I didn't get on your case when you didn't know a Komatsu D66S track loader was hydrostatic and you're an equipment appraiser.
as of 2006 bobcat no longer recommends engine oil in the hyd/hydrostatic system.
engine oil formulas have drastically changed over the years, as have some hyd oil formulas
BobcatofDuluth
www.bobcatofduluth.com
Re: Mixing 10w30 and Hydraulic fluid
Posted: 01/21/2010 07:10 AM
Hey folks! =) I came across this thread and thought I'd share the official word from Bobcat on this question. We get asked about this quite frequently at the dealership I work for (due to the fact that Bobcat used to ok this in their manuals). I just wanted everyone to be aware that this is no longer suggested or recommended. If you check a revised or current operation or service manual, the part about using 10W30 has been omitted. Here's the official release from Bobcat Company: "Bobcat Hydraulic/Hydrostatic Fluid is specially blended for use with Bobcat hydraulic and hydrostatic systems. Bobcat Fluid has been developed to meet the growing demands placed on hydraulic components, while engine oil is designed to meet requirements for use as an engine lubricant. Because of this, engine oil is no longer an acceptable alternative fluid for Bobcat hydraulic and hydrostatic systems. Viscosity. Engine oil viscosity is typically much higher than the acceptable limit of hydraulic fluid. Hydraulic fluid is designed for high pressure applications and with viscosity to operate effectively throughout a wide temperature range. Additives. Bobcat Fluid contains more zinc and phosphorus anti-wear additives than other brands of hydraulic fluid. Zinc and phosphorus adhere to metal surfaces of hydraulic components and act as a coating to separate moving parts. Additives in engine oils do not have the same anti-wear properties. Demulsibility. Under operating conditions hydraulic fluid is designed to separate water, engine oils typically absorb water. Foaming. Most engine oil is not formulated to prevent foaming. Foam is a contaminate that lowers performance, decreases filtration and can cause premature hydraulic component failure."
