Dave EX60
I had to remove the entire drive assembly on the EX60. I had put caps on the hydraulic lines. Thought we could use the machine to lift the drive as long as we didn’t move the travel levers. Bottom line blew the cap off and started pumping oil out. Is that normal? Thought if I didn’t move the levers no oil would flow.
