I bought a CAT dozer blade attachment (model# 231-5275) that is missing the wiring harness. Seller said one of his cows ate it. I pulled the cover off the solenoids and found what was left, and attached new wires. There are 2 solenoids, each with 2 wires. I need help understanding how the two solenoids should be wired to control blade tilt and angle. Each solenoid makes a sound when wired to 12 volts.
I won't bore everyone with what I've tried to date. To keep the message simple, if someone can tell me or provide a copy of the wiring for this attachment I would be greatly appreciative.
I will be using this on my Bobcat T200 skid steer that has a 14 pin connector, I am familiar with what each pin does, that's not the issue.
