Hallback
GW,
Thank you for the kind words. In regards to the down drive I had the one in our BU-94 rebuilt and it only cost twenty-five hundred bucks and that was a shop doing it. In all reality it is not that bad. The biggest thing to watch out for with those down drives is water getting into them. Change the oil in them every spring and if you're going to be moving that much in the winter time after it sits on a landing for a while pull the plug and drain any water out of it. If you have a hard pull up a hill assist it with a skidder or something so you're not putting all that weight on it. You won't break it down drive you will break an axle or a U joint before that. Good luck in your search and make sure to post up photos for us to see.
PS, what area are you from?
