Swampfoxo
Any adjustment u make be aware u might end up adjusting it wrong.
From the 2 different pics for the tube clean out location looks like 3.5" from the edge of the 3/4" hole to the center of the bolt hole which is about 4" center then there is a pic showing 3" centers. Which would be most accurate to be in the middle of the suction tube?I did 3.5 inches and 3 would have been better. I'll try to attach a picture. You won't believe the stuff you're going to pick off that screen. If your oil is contaminated you're going to use lots of oil (or diesel) whatever in order to get it clean. Even with cranking it and idling for a few seconds with the filter line off and running the old stuff through the lines and into a bucket till it runs clean you will still need to fill and dump the housing a few times till you get clean oil.
Mike
Powell River
HD Mechanic
Large pipe taps are expensive but I would drill for at 1 inch minimum hole 1 1/2 inch even better.
Look at coleman equipment or call dale weissDoes anyone sell a rebuild kit for the 580B shuttle? I am looking online but only see one for the C model and newer. Thanks
