An LGP five is the top of the line for soft work as far as I know, when things get jelly anything bigger may be okay for making a pass through but if you're doing much turning, the bottom can fall out pretty quick. Watched some video of Morooka dumpers working a levee repair, hauling gumbo off the top of clay and the clay out of the borrow pit to a reload pile going into artics and highway trucks, saw a 1500 Morooka with a good jag on fall through the crust. LGP 5 with pyramid pads made three passes from different directions to find a solid push on the dumper after the load was dumped, bumped the corner and the Morooka popped outta that hole like a cork from a bottle. Stuff was literally like jello, I was truly impressed.
