Iron Horse
Well i have now seen all the mulchers and slashers that are available to clear vegatation , none of them will process the amount of material i would feel comfortable to hold my hand out for payment . I have been thinking of a road roller with steel chopper feet all round . It would push over the scrub and chop it up into 8" pieces and leave it to either rot down or allow a cool fire to run through it . The vibrating front drum would cut through , maybe an 8" trunk . I had a search on Google for something that could be converted and found that Bomag do a modified roller for crushing rock in situ . If they can crush rock with one , theres no reason it could not chop scrub with a drum with chopper blades fitted front and rear . I would consider a machine that could process a 7' wide strip at 1.5 kilometres (1500 yards) per hour , productive . If need be i could use my extraction grab on the excavator to remove the bigger stuff . Mulchers are good at making an area look like a parkland , but for clearing big areas quickly , say to contain a fire thier finess is not required . It would have chopper blades like the trailed one pictured , and may even tow one like the one pictured . What are your thoughts ?
