69zfarmer
I wonder which is the strongest.This is a single axle 10' dump body.Both have single cylinders.It seems the 3 stage lifts higher.What are pros and cons?
I drove a truck once that had the 3 stage hoist mounted outside the box on the front with an A frame on hinges at the bottom of the front wall of the box so there was no doghouse in the box. It made it a lot easier to clean out the stuck asphalt than the truck I usually drove that did have the dog house... I'll see if I can't locate a picture of it... I'd stay away from the scizzor lift, I recently came across a truck with a bent frame where the scizzor lift was mounted... I put pictures of that in a thread called "Slightly Bent Hino", I have no idea how to link it to this post though...
