At some point of their lives, even the "Professionals" installed their first tank, I wonder if they were met with the same "chicken little" syndrome as we've seen in this thread? When I put Heavy Equipment Forums together it was my vision to have like minded individuals coming together to help each other wherever they could. That happens here for the most part and I'm very proud of our members and their willingness to exchange this information. coolcatman, thank you for maintaining your composure throughout all this.
One thing we need to remember as well is that we are all from different regions of the globe facing different rules and regulations. What might be a concern to some may not be in another place. Where I am, septic systems are governed by the County Health Department, but they only regulate new installs. Repairs are made without engineering nor inspection.
What I'd rather have seen in place of the calls for hiring a professional is to express your concerns about some of the difficulties in a constructive manner and educate coolcatman instead of trying to defeat him. Yes, there are safety concerns with placing a tank, but are there not safety concerns with nearly everything we do in life? Changing a tire on a car can be dangerous if not done properly.
Common sense should be used with this job and standard safety practices apply as well. One should NEVER place themselves under anything that is being lifted by a machine at any time, and one should not be in the hole while the tank is being lowered, this is one of the most important rules in working around equipment.
I don't consider myself a professional, but I've installed 3 1000 gallon tanks without incident and they all continue to work today. One I even had to lower myself with my J/D 410 as the hole was not accessible by the boom truck. I made a sling from my tie down chains and lowered each half, it was about all the machine could handle.
Digging out the old tank can take a while but by digging all four sides and a lot of wiggling with some crushing and they have come out without too much trouble. I've always put the new tank in the same spot as the old to minimize the amount of splicing to tie in the existing inlet and outlet pipes.
I worked as a laborer on a few tank installs so I wasn't going in blind, but I soloed on all 3 that I've done. coolcatman, you'll have to do some math to determine your grade for the floor of the hole to be sure the tank inlet and outlet are at the right height. what I do is over dig the hole just slightly and then use 3/8" stone to level the floor to the proper grade. If you've done your math right, you just set the tank once and it's both level and ready to tie in.
