Mcrafty1
I would think it would be closer to 1968 like the machine I'm working with. I'm not talking about today's machines.
Cat quit making 6Cs in 1976.I would think it would be closer to 1968 like the machine I'm working with. I'm not talking about today's machines.
I circled the button in green…once you select up to four pics…
then you pick thumbnail or full photo to post…
I bet our admins have prefs on which you/we post.
View attachment 266490[/QUOTE
The photo is on my MOTOROLA G phone...I Haven't figured out how to get it onto HEF yet, I don't have a file...just the photos in my google photos folder. I'm working on it now. Thanks.
As near as I can tell the book was printed 10/70 not sure of that but there isn't any other numbers in the back of the book.Look on the back page of your book for the publish date bet it's late 70s.
Bad Bob
I know it probably won't apply in your QLD climate but just be aware that a lot of the newer generation machines that use FD-1/FDAO oils in rear ends are performance-limited by the on-board electronic systems until the oil warms up to over something like 65 DegC in an attempt to prevent issues regarding lack of lubrication when the oil is cold.Since I just did a final drive up and now I know FD01 oil exists, and even though it is probably 70% more expensive then the other generic gear or TDTO oils.
We use 80w-90 in our gearboxes. Heavier weight oils might be "better", but you also need higher temperatures for them to flow as well. Up here in Canada, I'd only consider it as a summertime-only lubricant.
The only place I've seen 140w gear oil being used is in Radicon worm gear reducers.
Personally, I don't think it's a bad choice, after all, for a splash-lubricated system like how these final drives are set up, I think everything will be getting plenty of oil.Thanks for chiming in, I take everyone's opinion seriously If I even thought about using the machine in the cooler/colder times of the year I would have went with a lighter synthetic oil.
My tractor will only be used in the summer months, if I for some reason decide I'm going to use it below 32*degrees I'll dump it and go to a lighter grade, for now it's in there.
