Staying awake and focused
Greasyfitting
Savannah, GA
Field tech here how do you guys that have worked , or still work in the field stay awake and focused in the service truck. Some days I go in autopilot mode , or on long hauls I start getting sleepy. Any tips would be appreciated
chidog
kent, wa
In the day I had no problems staying awake, on some rare days I was on the road at 3 am, personally I looked forward to lots of heavy traffic when I was driving the service truck, I'd rather be driving than under some greasy machine. And I have never been a coffee drinker, cola yes so ??
BigWrench55
Somewhere
On long hauls or just plain tired and worn out from the heat. If I get sleepy or go in to auto pilot. I make the first stop that I can. Usually a fuel station. And I walk around drink a soda, smoke a cigarette, or eat a snack. If I am in the middle of nowhere. I will either pull over and walk around the truck. Or I call someone and talk. In the winter time (what passes for winter in Texas) I turn of the heat and roll the windows down. Usually good sleep at night gets me by. But I can get lulled to sleep by simply driving the same old route.
I've been extremely grateful for those highway turtles more than once when the truck started to drift. Now days they put the square grooves spaced close in the middle of the road and to the sides. As I got older I recognized the problem and would pull over in a rest area or a parking lot, lock the doors and roll up the windows, set an alarm that I kept in the truck and catch about a half hour of shut eye. Other times it was a cup of java, snickers bar and the cab windows wide open. I never had a truck that had AC but have been told that the cold air helps.
Greasyfitting
Savannah, GA
Me per
I've been rolling with the window down no AC. The AC makes me sleepy.
Mike L
Texas
Self employed field mechanic
How many hours are you working? Are you getting enough sleep? How long are you driving? Any underlying health issues? I know everyone is different but it seems like you should make it through the day awake and alert unless you’re running 18 hr days and not getting any sleep at night.
treemuncher
West TN
eatin' trees, poopin' chips
I was a caffeinated worker for the past 38+ years. I quit cold turkey back in January with only an occasional cup a couple-three times a month if that. If I got tired, especially at work or on a long trip on the motorcycle, I would pop a "Commando Coffee" into my mouth. 20 minutes later I was ready for the most extreme twisty roads! Commando Coffee = Folger's Single teabag style coffee - pull off the string and pop that into your mouth like a Skoal bag. Yep, it's going to be an intense coffee flavor but you get to swallow the juice and get a kick in the brain!
I've had days where I was falling asleep on twisty roads in the truck only 10 miles from home. Best thing to do is a 10 minute nap if you are that tired. It's amazing how much 10 minutes closed eye time can do for you to regenerate your alertness. No sense in falling asleep behind the wheel or the sticks. Safe is not stupid.
If I have major drowsiness issues, I always keep a hammock in the cab of a machine. Clear a spot near a medium size tree in the shade and then use the push bar to fine tune the hammock's slope. 30-45 minutes or so of rest and I can work well into the dark on a long day. Feed your body the shut eye time it needs - no amount of caffeine can compensate if you get really tired. I've overdosed on caffeine a few times trying to stay alert and unless I tried a stronger drug, which I won't do, needed sleep is the only cure. Even 5-10 minutes of shut eye makes the difference for a quick reset of the brain.
Old Doug
Mo
If your under 30 you ether have a medical problem or just not getting the sleep you need. I think back to some of the stuff i did when i was younger i never know how any one could get any thing fixed working 8 to 5. I have another problem now i try not to do any service work because i cant stay out on a job all the hours i would like to and that realy works on my confidence. I have a job today mounting a coolant over flow tank easy peasy but it fills like a big complicated job.
JD955SC
The South
Get a sleep study done, you might have sleep apnea. Find a sleep disorder clinic, don’t go through the hospital (hospital is complete wallet rape even with insurance, my insurance covered 100% of the two sleep studies my ENT ordered because I did it through the clinic while my coworker with same insurance had to pay many thousands because his was done through the hospital).
Greasyfitting
Savannah, GA
I work 7 am to 4-5 usually some days 6 or 7 pm
MarshallPowerGen
Northwestern USA
Generator Technician & Equipment Mechanic
How's your diet?
Cut out junk food and sugars. Take some caffeine.
That's always my biggest advice for coworkers to stay awake. Lots of guys that were dead to the world after horking down a bag of fast food and jug of pop, or dozing half way through the shift after the energy drinks wore off and the sugar crash hit.
I usually pack a sandwich and mostly eat nuts and jerky on the road. Drink lots of water (hard to doze when you need to pee) and pots of black coffee (ALL DAY) even in the heat. I have a cheap coffee maker that lives in the truck and runs off of the inverter when I need a refill.
Mike L
Texas
My eatings not the most balanced. I used to each lunch but I haven't been eating lunch during my shift recently just drinking water , and Gatorade
Bingo! Tell him what he’s won, Johnny! Eat some lunch dude. Can’t grind out in the field on an empty stomach. I always bring my lunch and keep some crackers stashed away just in case. How old are you?
