- Joined
- Mar 11, 2012
- Messages
- 11,165
- Location
- Central New York, USA
- Occupation
- Retired Mechanic in Stone Quarry
Also let us know what goodies you find in the crap in the belly pans, might finally find Jimmy Hoffa!
That leaves Dan relying on a slack service man not having removed the bearing parts after a transmission repair , which I doubt .I don't want to sound to contrary but the fuzz like that was in every dozer of that era that I ever worked on. The bearing parts might be some failure twenty five years ago. If it was in some steady state operation doing 80 hours a month and the history was tracked and known, then I might suggest a tear down. As it is, I would run it for a bit, check pressures when warmed up and then check for vibrations and sounds. Even if there is something gone south, what will it hurt to run on that old of a machine. Normally the trannys just lock up and the machine stops moving. The damage inside is already done.
