Reluctantly working on my wife's uncle's 2004 Genie Z45/25. SN Z452504-23386. Dual fuel Ford LRG-425 engine.
Symptoms: Intermittent travel, hold the joystick in either direction, it'll stop and start and is a royal pain to drive.
I have:
Verified all 3 limit switches for the booms are good and the circuit completes at Pin 4 of the ALC500 up in the platform.
Verified turntable limit switch works and the circuit completes at Pin 3 of the ALC500 up in the platform.
Verified the joystick provides a clean, consistent .5-4.5 volt signal to the ALC500 up in the platform, resting at 2.5.
Foot pedal switch works properly
Power and ground to the board checks out.
Now here's what I've found it is doing. The ALC500 PWM controls 2 solenoid valves right on the pump on the end of the engine for forward and reverse. With the engine off, it sends out about 3.5v right away and ramps up to 5.5v and stays there when the joystick is moved in either direction, and the little LEDs labeled FWD, REV, and BRAKE all light up.
Start up the engine, this same signal comes and goes while the LEDs flicker. We scoped both outputs, they do the same thing. You can tell when it's about to slow down as the signal drops out going to the solenoids and then it coasts/stops and then starts moving again.
I'd LOVE to condemn the board but this thing is $1400!
The schematic shows no reason why the engine running should have anything at all to do with operation of the hydraulics (besides of course the pump being powered up). The ALC500 in the platform, as far as I can tell, receives no input that would signify the engine is running. It seems weird that it would act up exactly the same in BOTH directions and only when the engine is running. Maybe someone will have something else I can check into.
Machine used to work flawlessly, and then started acting up intermittently and now it's barely drivable.
I have:
