WTB! : Looking for some sort of autograde for my D5M XL
Sleeper90
NW Ohio
Hello all, haven't been on here for quite some time, heck even had to make a new account cuz I couldn't remember my old one!
Anyhow, I'm looking for an autograde system to put on my D5m XL that I recently purchased. It previously had something in it before at its owner since new. (Operating engineer school)
Please give me any and all info on this as I have never been around it. What will work best for it? What kind of cost am I looking at? I have heard from equipment dealers that you can pick up used systems very cheap due to technology changing so fast..any truth to this? Anybody have anything they're looking to get rid of? Thanks guys
Chad@SitechTR
Memphis, Tn
Really depends on the type of work you are doing, and how much you are wanting to spend. A laser system may work well for you. It also depends on what may have been on it before. If it's still wired up for a system, you might benefit from renting a system when you need it.
Sleeper90
NW Ohio
Thanks for the reply. Here is what it looks like now:
This is inside the cab
This is outside the cab
This is on the blade on both ends
Sleeper90
NW Ohio
The 2 bolts on the inside of the cab is the only thing that I can find that would've had something to do with some sort of monitor
Chad@SitechTR
Memphis, Tn
I'm pretty sure it had a Trimble Site Vision system on it. It's a pretty outdated system now, but there are some people that are still using it.
Sleeper90
NW Ohio
I haven't been able to find any cables. Could I pick up a system like this anymore? Could prolly get very reasonable being outdated? I don't necessarily have the need for a laser system but it would make jobs go more efficient for me
Construct'O
SW Iowa
Dozerwork,tiling plus many more!!!!!!!
My guess they were just using a laser and receiver.Mount on blade could have just been a pole to mount the receiver on.If it was auto there should be a hydraulic valve to run the blade up and down.I would be looking for that,under the floor plate or below the seat some where.
Unless you have a bunch of 3D project GPS get expensive.If your just doing laser work then laser works fine for pads,but with a graded laser you can do some 2D slope jobs.
Knowing what to look for in used GPS equipment is the catch.Outdated means just that! in some cases.Good luck
Sleeper90
NW Ohio
What kind of system should I begin to look for in a 2D laser setup? I have a Leica single slope laser right now, I know single slope can only do so much, but could I start with that and just get the "other" pieces for the dozer for now?
Shimmy1
North Dakota
Yes. Only thing that matters to lasers is the color. If you are only using on the dozer, a couple of LR50R's would work great. They would be capable of being used with a auto-grade system in the future.
Chad@SitechTR
Memphis, Tn
if you are just looking for a 2D indicate only solution right now, one or two LR50's would get you going. If you want to run automatics, the machine would have to wired up again. It's all about what you want to do and how deep in your pockets you want to get
Sleeper90
NW Ohio
What other options do I have besides these LR50s ur talking about? Like I said I'm new to this (if you will) "deep" into laser systems so I guess I'm just trying to get as much info from you guys as I can to start piling up some research. Give me something to do over the turkey-day weekend!
Shimmy1
North Dakota
The receivers are all basically the same, Bullseye, Futturra, and Spectra are identical. The +3, MR3, and LR30 (brand accordingly) are strictly vertical indicate receivers. The +5, MR5, and LR50 have vertical plumb compensation within +/- 2°. The +6, MR6, and LR60 have angle compensation. This means after a simple calibration process, it will compensate for the angle of the stick on an excavator. I'm putting the manual for a LR60 on here, just disregard the info about plumb and angle compensation if you're looking at the base (+3, LR30) models.
  • LR60_Users_Guide.pdf
Sleeper90
NW Ohio
Thanks guys. I will check them out this week/weekend. Appreciate all the info! I'm sure I'll have more questions after I get reading!
