Yellowdog
- Joined
- Oct 22, 2004
- Messages
- 208
There have been 9 guys that have responded on this post. Some of them own one of these machines and others have "heard about" or "seen something", others troll the forum, and then post and run, but most likely, most have not owned all of the models you are looking at.
The forums and some of the information can be good, but I would suggest that you digest the posted information with a grain of salt, visit as many of these machine's dealers that you can, ask lots of questions, ask for customer references, and then demand a demo so that you can physically see if the machines will do what you want it to do. Good luck.
Amen. It amazes me how many guys chime in (not calling anyone out here specifically) after renting a machine once or twice, watching one work across the road, or hearing from a buddy and then post what they think.
The best advice was just given. Take time, investigate and put seat time into a demo of the brand you are leaning towards.
I personally put nearly 3000 hours on 3 Bobcat K series large frame, high flow loaders (2 s300's and 1 s330) used about 50% of the time for mulching and they have been low maintenance.
I also owned, briefly (200 hrs), a CAT 272c high flow. While they weren't tracked units, the motors and hydraulics in the CAT are the same as the CTL and MTLs that share the 90 hp machine. The CAT will run the attachments listed well. The Bobcats s330 runs the same ones well which leads me to think that the T320, (same motor but slightly more fuel and more psi) will run the mulcher better. I am not sure what was meant by "fit and finish" but Bobcat K series is finished out just fine compared to my C series CAT. yeah, cat has some neat upgrades like air seat but you can make the Bobcat cab just as sealed as the CAT c series with a little work. the controls are very similar if you go with Bobcat SJC. Either machine, in my opinion, would do what you want and used CATs are certainly a bargain.
