makee
Engine of the unit is running, only that it can't transmit power to the transmission causing the unit to be un-operational ..previous defect is that when in low gear unit is moving well but when changing to high gear unit is lacking of the desired force it should have produce. First thing we check is the control valve ass'y we pulled it out and overhauled it replacing gasket and o-ring..after refitting the control valve ass'y into the unit the problem become bigger theres no movement no forward or reverse..what we should do? your ideas and expertise can help a lot.. thank you and more power to everyone.
