What kind of tractor?
SKP 428
COLORADO
What kind of tractor is this ,I bought this a few years ago and want to see if any of you guys know what it is. The engine a JD it has 2 cylinders water cooled and is gas and has a 3 speed trans . Looks home made to me .Hand crank to start it .
Deas Plant
Gold Coast, Queensland, Australia
Wottizzit?
Hi, SKP428.
It has a sort of a Panzer look about it but I never saw a Panzer with what looked like an old pick-up chassis for a main frame and I've never heard of a Panzer with a JD diesel engine.
Yer got me.
SKP 428
COLORADO
Here are some more photos of the tractor
rino
Barberton, Ohio
Drive steel bed Dump Truck for a paving company
Could that be an early Economy? They were designed for the farmer that had more then a tiller would do, and less than a Ford 600 - 800 work load!
DarrylMueller
Altamont Pass, Livermore, CA
Excavating Contractor & Operator
What make is the engine, are you sure it JD. The front wheels are not anything Deer would use. I suggest going to the JD two cylinder club and see what the think?
jhill
Thumb of MI
The engine is a JD engine from either an L tractor or an old pull type combine. The rest looke home made. Deere did not make the chassis.
Jerry
rino
Barberton, Ohio
Jerry I agree. The JD was an after thought! That was a spare engine, or a cost effective backup to something else! Those engines were on the JD Mod L, A, LA, and AL, as well as a portable power unit used for combines, and pickers.
