Radrock
OK, I had to toy with this a little. I have been operating graders for most of my 40 year career. I just started operating a 140M about 4 months ago. I like lots of things about it and if I had nothing to do but maintaining haul roads or even building them it isn't too awful bad. But any of you old-timers out there that know how to grab a handful of levers at the same time know what I am talking about when it comes to grading a very tight corner. It is a combination of wheel lean, articulation, steering and blade control. This joy stick works fine with the steering and I can get along with the articulation fairly good. But you watch your left hand doing all of the work while the right hand is merely moving the blade up and down and turning the circle. Oh and running the blade side shift. I think the wheel lean is very very unusable and is probably the one thing I hate more than anything. I used to do lots of small turns using nothing but the wheel lean so I did not have to remove my hands from the rack. You can accomplish this pretty easy now with the joystick turning. You can grab both the wheel lean and articulation with your right hand at the same time (pull them both for right turn and push for left turn) in the old rack style. I created this drawing changing things around a little how I would like to have a joystick controlled motor grader. With this you could still hit the wheel lean, articulation and steer all at the same time. Oh did I mention that I think the hat switch is a piece of junk?? hahaha.
Well I just thought I get an opinion and see how much of you know what I could stir up. Of course I'm too old to ever see a change in them again but it is always nice to have a wish list.
Oh and those are slider switches...
