As if anybody here didn't already know this, here's an example of what happens when you don't use the grease gun. JLG 80HX boom lift, steering pivot pin, pin siezed in brass bushing in the axle housing that it's supposed to pivot in. Instead, it rips out the pin retainer bolts underneath and causes pivot action to happen in the motor housing, where it's not supposed to pivot. Tried a little bit of heating with rosebud, unh unh, that pin is stuck! Now I ain't about to spend a half a day and empty the tanks of my gas axe trying to fight that pin out, nope, I'm going to cut the pin in half. Get out the Jancy Slugger drill. Annular cutter bits are so sweet to work with. These things chew through steel like it's wood, and leave a true/clean hole.
Chewing through that pin like it ain't nothin'
