Waldon 5000
Discussion in 'Compact Wheel Loaders' started by Effinay, Jan 10, 2013.
  1. Effinay
    Effinay Well-Known Member
    Dec 15, 2011
    103
    Getting organized with my own small business
    Pelham, NH
    Maybe somebody could offer some diagnostic help..... My early 70's Waldron has an issue with its pump (I think:beatsme). I've owned this little machine for a year or so with the intent of doing a little work to it and then flipping it to move into something a little newer/larger. Good plan except for this chronic condition. As I'm driving around and the hydraulic oil is still "cold", the machine seems to drive reasonably well. As the hydraulic oil warms up there is a significant loss of power. So much so that I can't get the machine to move in "high" gear. And I mean no movement at all. Sits there and makes sounds like it wants to go, but nothing's happening. Change to Low range and I'm off and running again but at a greatly reduced speed, and even this drops off to a very slow crawl. The hydraulics for the bucket don't seem to be affected, nor does the steering. Both of these systems work fine with no loss of power. I did the rudimentary stuff like checked resevoir level (plenty). Put my hand on the pump, just seemed warm, nothing out of the ordinary. Anybody got any ideas as to where to start? I thought about changing filters, and maybe change the hydraulic oil. Probably wouldn't hurt, but I don't think it's going to be as simple as that....
  2. mikebramel
    mikebramel Senior Member
    Jul 16, 2012
    1,084
    milwaukee
    You need to see what the line pressure is before throwing any parts at it
  3. Effinay
    Dec 15, 2011
    103
    Pelham, NH
    Thanks for responding Mike. I've got a service manual for this machine. Now need to find the right equipment to do this test and the locations to tap into.
  4. mikebramel
    Jul 16, 2012
    1,084
    milwaukee
    Should be a port right on the valve that controls the motor. Probably a hex plug.
  5. Effinay
    Dec 15, 2011
    103
    Pelham, NH
    Hey Mike, thanks for the help with this. Tomorrow I've got to check to see what type of fitting I'll need to adapt to. I've got a pressure gauge that goes to 3000 psi, so all I need is to have a hose and some fittings I think. Should there be some way to bleed air out of my test set-up?
  6. mikebramel
    Jul 16, 2012
    1,084
    milwaukee
    I think a 5000 is from the 70s. So pipe thread 1/4 or 3/8 I would think. Wouldn't worry about any air in the system
  7. William Baan
    William Baan New Member
    Apr 27, 2017
    1
    Woodstock Ontario
    I bought a older Waldon 6000 with a bad engine, I put a perkins 4236 in. I got it running well but have the exact same issue with very little power to the wheels, I was wondering what did you end up replacing?
  8. mikebramel
    Jul 16, 2012
    1,084
    milwaukee
    Take a picture of the pumps and motor
