Thats funny you mention the inspection port heavylift,the farmer that we were building the lake for said we may as well knock a few more holes in the block then next time we could work on the engine without pullin the oil pan
I'l probably just keep running it like it is,the patch seems to hold fine with no leaks.We did a complete in frame overhaul on the bottom end,rolled in new rod & main bearings,new piston & sleeves.I did take the cylinder heads back to shop to rework them,had to replace one bent valve and just lapped the rest with some compound.I also replaced all 32 valve springs.The hardest part was getting all the metal out of the engine,I pulled the blower and it looked like a bomb went off in the air box,oil pan was the same.Spent allot of time using a shop vac & magnet.
I ordered the engine rebuild kit from
www.btmccorp.com I've used 3 engine kits from this company in the past on cummins and detroit engines and have nothing but good things to say about them.They know what there doing,service is quick,price is great! Parts in my kit were all federal mogul and sleeves all fit great in the block.
I just used regular rtv silicone gasket sealer on the patch TCS,I did gombo it up pretty good and put it on all the bolts before I installed them.
Boy aint that the truth scott.Only time i ever had a break down in front of the shop door was when the shop door fell of the track:lmao
