W20 Case wheel loader, Problem engaging in forward and reverse.
I have a W20 case wheel loader that will not engage in forward or reverse. Always worked fine untill now. I checked straners in transmission, linkage, the spool on the control valve. From the foot valve there is an air line which goes to a valve that pushes the spool, thats works fine also. The foot valve for the torque converter, trans, has an air leak could this be the problem. I checked the foot valve and that is returning all the way up and is not stuck from dirt etc. Pump seems fine, I have all my hydralics, bucket etc. It acts like the trans is in netural.? Wanted to see if anyone has had this problem or may know whats going on with it, before I head to case. Thanks :ointhead
