I guess the rear end on my Autocar is made by these folks. Model number is SSHD, this tag is on the power divider. I pulled the yoke off then the casting that holds the seal and bearing race. Also there were thin metal gasket/shims between the casting. I tried to pull the bearing off the imput shaft with a puller and I pulled the wire that holds the roller bearings, now only the race is on the imput shaft. How do I get that race off its to tight to get the puller behind it ? Years ago I had a chip fly off a race and lost my sight in one eye now I need a better idea for this one.
