Volvo EC15B XTV older machine but low hours 600ish
Starts & runs for a couple seconds then instantly shuts off.
If i hold the key in start position is stays running until i let off, then dies right away.
Most of what ive read says that it is an electrical issue? Solenoid perhaps? Relays?
Recently changed my fuel filters, not sure if an air lock could do that....ive already cracked the injectors trying to bleed the motor of any air locks
ive checked the battery cables, all fuses are good, cleaned some grounds, inspected ignition switch .....
Just wondering if anyone had any thoughts or ideas that i may be helpful before i bite the bullet and take it in.
thanks in advance
thanks in advance
