kthompson
Good morning and pray each of you are doing great.
Been a while since have been here but back to topic that first brought me here, electric over hydraulic not working at least when first cranked up.
I have worked with the issue all these years mostly as my need for the machine had got less so was not worth pulling out 4 to 5,000 for the control panel Volvo shop was sure it was and then when I told them how the machine could sit there and run normally for few minutes it would power up and work fine they would say but that does not sound like control panel for when they fail it is total failure. So I keep hoping and hoping and well recently felt okay time to bite the bullet when control panel and thus the electrical system stopped after it had been working which had never done that. On a tractor forum someone suggested running new power and ground to the cab to see if it was not a connection issue so said now is the time to make that try. Well went to remove the ignition switch to see about running new power to it and the control panel lite up as it should when the switch rotated in the console. What? So I stopped and it worked fine for that day and two afternoons the next week and then last Friday and Saturday nothing so last evening removed the switch and checked the voltage to the power wire to it and grounded on the machine and I was shocked, it read from 3 to about 5.5 volts depending on which terminal I had the lead on. The quick thought was yep bad connection so need to run new power straight from the battery and a JD mechanic word came to my mind, some machines run real low voltage so be careful in trying to bypass anything. So that voice over came my I am so tired of it right now any thing would be an improvement to but not at the cost of control panel that may be fine. To make it worst I could turn the key on and the control panel powered up beautifully. I tried that several times and each time it worked fine. So I did what any average shade tree mechanic would do I left it! Wondering okay should I do what? It is now working with more movement of the ignition switch (it was in my hand with wires having been pulled off and reinstalled so possibly cleaning the terminals or go ahead and run direct wire with what may be higher voltage that burns it up or that supplies the proper voltage. That is when you all came to mind!!
Ask the pros if they know what the voltage to the ignition switch on a Volvo EC 45 should be? At present my thought is to spray the terminals and the switch with contract cleaner and reinstall and just see what happens and I will do that if a few more tries give 100% correct results. But the voltage still may be low due to bad connection or something between the power connection and the switch and I am at point now have the frame of mind it is time to repair or replace.
Thanks to each of you. Kenneth
