JD750B
Working on an 580C recently given to me. It has been sitting for a bout 2 years. Replaced the bad lines on the hoe and now am working to get the engine going so I can bring it home. Engine starts right up but loses power and then dies after about 15 seconds. I changed the fuel filters and bled the system several times but it is still doing the same thing. Sometimes it will run longer prior to losing power.
No leaks, gravity fuel system and good flow to the pump. Fuel from #3 and #4 injectors seems to be weak relative to #1 and #2. I have not checked for blockage on the return line yet but will do so. Any suggestions or secrets to getting this system bled completely.
Thanks in advance.
Thanks in advance.
