Ole Gal
- Joined
- Nov 25, 2014
- Messages
- 46
- Location
- Harrington, Delaware
- Occupation
- Construction: House framing and steel erection. R
Nige,
I am sure these tires are bias ply, although I could not find any indication on the tire. They are nylon Mohawk Chief, and and they show very little bulge as might be typical of radials. They certainly have very stiff sidewalls which may be due partly to being old (like me).
Mitch,
Since you mentioned the arrows, I also looked for arrows on my tires indicating the direction of travel. I thought I understood the proper orientation of tires. Only one thing is clear to me now, I do not understand tire technology!! The pictures are of the tire on the left hand side of my grader which I thought was on correctly, but would you look at the arrow!! I can not believe what I am seeing. The arrow indicates that this tire is turning in the wrong direction! So as you should be able to see in the photo, the chevron angle is pointing in one direction and the arrow on the sidewall is pointing in the opposite direction. So I check on the tire on the right side of the grader. The arrow indicates that it is turning in the correct direction for the driving wheel! I do know one thing for sure, one of these tires is on correctly!
Both of these photos are of the tire on the left hand side of the grader.
Mitch,
