Hellbringer
Hi Guys
I have been working on this machine for a while and i have all the problems sorted out but one.
I have an oil leak from the connection between the 2 drive pumps. I have looked through the parts manual and the service guide and it looks like there should be 3 o-rings on that surface (2 smaller o rings for the passage between the pumps and a large ring that goes around the shaft housing) i have made sure those 3 o rings are installed and still have a leak.
About the leak, it leaks when the machine is not running, as soon as oil in put into hydraulic tank, it starts a slow drip, the speed of the drip does not change if the machine is running (it is not under pressure)
Has anyone run into this or know what the fix might be?
Thanks
Mike
Thanks
Mike
