LedgeEnd
Hello Everyone! I just slashed the back left tire on my case 90xt skidsteer. The cut is deep and runs half way around the tire in the middle of the tread. The only thing I can think happened is that I spun the tire 1/2 revolution while it was on something sharp in the ground???
If I continue to run the tire should I fill the slot with something to keep debris out?
What happens to the stability of a skidsteer when a back tire goes flat?
If I replace the tire do I need to also replace the front one so the the tread is the same?
Is it important to have matched tires?
Any other tire comments are welcome also.
