Dustin Mason
Chavez, that is definitely a dry clutch model. You won't find a floor mounted neutral cutout switch on this unit.
I noticed the leaking transaxle fluid in your transmission picture looked a little milky, like it has water in it, and the input seal definitely needs replaced, something to think about.
The rear hoe sub-frame mounts to the tractor mainframe in 4 places. The bottom two mounts are just big hooks on the mainframe, with tightenable pins on the top two mounts. Over time they will wear some and work loose, it sounds like there is not too much play in it from your description, and any play it might have can probably be cinched up from tightening the linkage that holds the top pins. You will find these under a plate right between the foot swing pedals and the seat. You will see two large threaded rods sticking up, with nuts on them.
cat320 and Mr. Frazier are correct on the hanging rod you have a picture of. That controls the return to dig feature. Mine is like cat320 described, hasn't worked for years and I dont miss it, easy fix though.
There are two pins that hold the rear hoe boom to the swingtower. In your pic, that I think I have reattached below, that is the square headed pin. The two bolts fasten a small flat plate which retains each pin, so, it is not a crack in respect to the terms as cat320 referred to it ; that is how it is supposed to look.
Dustin
Dustin
