And a point of etiquette - is it OK to continue posting to this thread or should I start a new thread?
- thanks
Well, IMO, I think you should post it on this thread. This thread has become a resource that's loaded with JLG 40F information that is easy for other readers to locate, especially those with a 40F.
BTW, you don't cut the rod eye off to replace seals, you take the cylinder apart, then remove a nut that retains the rod piston on the rod, then the cylinder gland (head) slips of the cylinder rod. As far as I'm concerned, whenever I go through the trouble of taking a boom apart to repair a leak from the cylinder then I'm going to replace every seal in that cylinder because I don't want to have to go back in there for a while.
In my case with the parts, I have a local Parker Hannefin seal distributor and they typically can provide me with most any type seal. Hoses I get made at local hose shop. The wire cable, that's a different story. First of all, it ain't cheap. Nothing with copper in it is cheap anymore. But in my experience, after making many searches for suppliers of cable, it seems JLG will either match their price, or many times JLG is cheaper. I have a theory this is because JLG purchases miles of wire cable in a years time to build machines so they probably get it at a very good quantity price. The thing is, you have to use a cable that is designed to flex for many cycles. Typical SO, SEO, or Tray cable won't work in that application.
Am I a distributor? Nope, just someone who has been working on them for years. I haven't worked on every model they have made, but a good many of them. As for parts, it's generally best to work with someone close to you. That is, if you have a good dealer that's a pleasure (not a chore) to work with. Most equipment rental stores are JLG distributors. If you don't have a good distributor, the outfit I buy parts from is in Shippensburg PA, not far from JLG. I've been buying parts from them for years and Eric and Jeremy knows the machines and parts well. 1-888-321-3217
