Jonesy
Rebuild update: Gas tank is off....not too bad inside, but noticed some slight seeping on the bottom...gotta clean it up and see about repairing....tricky business repairing gas tanks. A friend has some of that goo that you coat the inside of the tank with that is supposed to seal it up from the inside. He says it works well. Might give it a shot so long as I don't end up with any large holes. Although there wasn't much rust in the tank, the filler screen was pretty rusted up.
Got about 18 hydraulic lines off, marked, and diagrammed. Still got a long way to go there.
The basket is off, and in the shop for repair.
I removed the double-chain link from the engine to the hydraulic pump so that I can continue to occasionally run the engine. Glad I did...the chain is rusted up and in need of replacement.
Good news....I pulled the hydraulic filter out of the tank, and it looks like new....doesn't look like I'll have any issues with the hydraulic tank, although I'm working on taking it off of the unit in order to get all of the stone quarry crap out from under it.
