Well......you'll need to support the boom on something very solid while you work. Higher the better. The best way is an overhead crane if your shop has one, if not a vehicle hoist, a large mound of earth, or even the roof of a sturdy building. Be carefull, don't take any risks. You're directly in the line of fire if that boom should fall for any reason. I would try and leave the barrell of the cylinder in place, just undo the gland and remove the piston & rod, reseal it, checking the bore of course while it's opened up. If it's scored, you'll have to pull the barrell also.
Hydraulic filter is JLG #2120055. I've never been able to cross that to anything.
(if you're not in a big hurry for it, I can send you one )
OFF, I'm new to the thread but have a mid 70's 40F and am in the process of re-wiring the machine but looking at all the systems while its down. What is the fix if you are out of room for adjustment on the brakes.
Also, big question is while doing a function test on the systems (auxiliary pump mode) one drive motor does not spin, I have both removed from the hub to check seals etc. which made it convenient to do the electrical test but we're scratching on head why one one motor spins. Any help would be appreciated. BTw Racine valves on mine. Thanks.
OFF, looking for a filter are any available, thanks.
I'm new here and not having any luck searching for other threads on a JLG 40F. Does anyone know of others?
Thanks for the welcome! I have been learning a lot form you OFF and numerous others over the months just reading the thread. Quick question if your still on, I know I saw it somewhere in here but running out of time to review all the posts do you know what the two side by side valves (Racine) exactly do mounted up on top. We have the others mapped and labeled but confused on them believe they are high drive?
Thanks a bunch! As you may have guessed we're unsure because of the fact one drive unit isn't spinning. I attempted to try the swap you suggested but ran out of time. Two more questions if I could, is the other side of that the high speed valve low speed and since I'm a novice on hydraulics is the spool fixable (providing I knew what it was) should that be the problem?Best way to tell what that is - pull the wires off it and see what stops working
(pretty sure that's high drive alright)
Hello Gurus of the 40F! I can't seem to get a good answer on the hydraulic fluid around here. The manual calls for Sun 2105 and no one can find it or a crossover. I've looked into a bunch and the viscosity index (170) is throwing me for a loop.
What should I put in there?
BTW OFF, thanks again for the last reply's and was able to cross those numbers to a Napa1436 so will take the old one over there shortly to make sure.
What we always used in them was a common #22 hydraulic fluid. That was the standard. In colder weather however that didn't work very well (-20 to -40 range).
We've also used ATF, synthetic ATF, and 0W30 motor oil.
I had a thought is it possible there is nothing wrong with my drive motor because we only tested it in auxiliary power mode, should I wait until Saturday when I run the motor to bring full pressure before I swap motors and tear into transmission valve? Just thinking.There is only one drive valve. It's in the group of 3 valves mounted low in the chassis. (lift/swing/drive) Hi drive will be a single solenoid valve that opens & adds extra hydraulic flow/increased volume to the drive circuit.
As far as that transmission valve goes, you should be able to save it just by taking it apart and cleaning it up, looking for broken springs, making sure the spools operate smoothly in the bores, etc. Rust is enemy.
I'm out working on the lift and electrician Bud has a question: per the manual schematic it shows a select relay and a high drive relay we never ran across either one, are they not on all models?
One other question is the high drive solenoid mounted on the rail with the rest, we wouldn't be asking stupid questions but as with most posts I've read the wiring has been #%****%^***, the only original was going up the boom?
OFF, you are amazing on these machines! How did you learn these things so well?
