John Deere has taken over from Cat to be the supplier of dozers(not sure if they got the graders and loaders as well) to the Australian Defence Force who purchased 850's. I would imagine there is someone in Cat with a very sore backside for allowing this to happen.
LDK,
What has been the problem with the tracked skid loaders and what models have given these problems.
Firetrack,
They are 322's, we got them just before the joystick model came out over here, I think it was sometime in 2008. The main problem was with the valve block under the seat area. The valves leaking badly was/is a constant problem. Hoses and seals going has been a problem from day one. They did work in a lot of dust at times and it was found that they were less trouble if we could keep the belly plates clean. So maybe it was heat build up, friction or a combination. Whatever it was, we would never touch another one!
We had a CAT 246 working in similar conditions and it gave a lot better service. I am not saying that because I am a dyed in the wool CAT fan , I have no loyalty to any particular brand! I have had good service and bad from several of them.
Hope this is of some help.
