Terex TS14B blower
stars&bars44
Trinity NC
Earthmoving
Hey everyone! Just got a TS14b from an auction. Had some old Euclid S18s with 6110bs in them but never a little 471. The back engine won't shut off with the blower. You flip the lever and I can hear it close and motor slows down but chugs black smoke. It runs at a very low idle. Had to loosen fuel lines to get it off. Any ideas? Could it be a gasket in the box? Or do I need to go into it?
RZucker
Wherever I end up
Mechanic/welder
Could be a bent flap, I've seen a few that leaked enough air to let the engine idle. Didn't the normal shut down work?
stars&bars44
Trinity NC
Earthmoving
Well I thought that was normal. Never had a twin engine before. Front pull the pedal back. Looked for a pull lever up there in cab for back. Guessing it would have something near back engine for shut down?
56wrench
alberta
It should have a spring-loaded shut-off lever on the governor. If it has been shut off too many times with the emergency flapper, it could have sucked the shaft seals out of the blower.The flapper is for emergency use only, such as a fuel injector rack sticking open, not allowing the regular shut-off to work
stars&bars44
Trinity NC
Earthmoving
Yeah I found the shutoff. The lever had been broken off. I know some of the ts18s had a pull handle that's what I had been looking for. Thank you. Changed the oil and filters, gotta put some grease on it and clean it up and paint it. Thanks again for the help guys.
stars&bars44
Trinity NC
Earthmoving
Forgot to post pics. Been using pan for a few weeks, and no problems.
Buddy
Newtown , Virginia
Equipment mechanic (Retired)
Nice looking machine you have.
I have one of those TS-14 's here in the building .
They are good machines.
Even look better with fresh paint. LOL.
Former Wrench
Montesano, WA
Retired
I would get the shut down lever working. It causes premature wear to blower seals to use the emergency shutdown flap to kill the engine on a regular basis.
