Terex Franna crane service info
Mobile diesel mechanic
Hi all,
I have service to do on a Terex AT-15 Franna and on the service sheet there is a couple of jobs I can find any info on in the manuals.
“Adjust rear boom pivot bearings”
“Change winch gear box oil”
“Change winch brake oil”
Can anyone offer some advice in regards to oil drain and fill locations and adjustment procedures and anything to check on during inspection
Cheers in advance
Tomo
BillG
S. Wisconsin
Look up Kurtis at Cutting Edge Engineering, he is on Utube and also is in Austrailia. He has one and is the current project and may have the info that you need. I don't know if he has manuals or not but it's worth a try.
RocketScott
Lexington, KY
What kind of winch does it have?
The brake should have a drain on the underside. Might have to tilt the boom to get it at the bottom. Same with the drum drain on the other side
Fill for the brake might be through a vent on top. Drum will probably fill through the same hole you used to drain, just need to cable up or down to get it on top
