SMP Design
Hi All,
First post. I come across this site while doing some researching on telescopic boom designs. I'm a mechanical designer and I am currently designing a machine that has a 3 stage telescopic boom similar to a telehandler and also has an energy chain inside the boom sections to connect hydraulic hoses and low voltage wires to an attachment on the end.
I'm tyring to find information about the different types of boom drive systems. As far as I can tell there are three different types:
1. a single double acting cylinder with a rope and pulley system
2. a single double acting cylinder with a sprocket and chain system
3. 2 off double acting cylinders diametrically opposed to each other.
Basically I have ruled out option three because it takes up too much room inside the boom sections and doesn't allow enough room for the energy chain. I know that there is a school of thought from a maintenance perspective that the energy chains should be mounted externally for ease of access however the application is a very arduous environment and so much so that the energy chain is at high risk of impact damage.
For those interested the machine is a Liner Handler used to assist with the exchanging of worn liners inside a hard rock grinding mill.
Anyway my research has led me to believe that option 2 with the chain and pulley system is the preferred option of many manufacturers especially the telehandler machines. Having said that I am wondering where I could get my hands on some diagrams or manuals on how these systems are set-up. I've design numerous types of telescopic devices but never with a sprocket and chain drive system so any help, information or advice would gratefully be appreciated.
Cheers!
Anthony
Cheers!
Anthony
