gary808
hey we just picked up a tampo 10/12 ton wheeled roller ,its a x military unit with under 300 hours on it .
im not sure on the specific model because they painted over every tag on the machine .
the problems were having with it are it has almost no power to drive in either directions and the viberator wont start ,the military put a brand new sunstrand vib pump . ,
we had to pull the 453 out of it to service the overcenter clutch and change some rusty bearings in the funk box.
were going to run the pressure checks on the pumps when the motors back in the machine but were just stumped as to why the whole system is down ,i had the tank opened up and the filter looked clean and there was no metal or junk in the tank pointing to a pump failure .
they have atf in the system should it run that? or should it run 10 weight hydraulic trans oil ?
any imput would be alot of help .
