Does anyone out there know if a newer Yanmar 2TNV70-PGA 2 CYL ENGINE will bolt in replace the old 2TN66L 2-CYL engine in my Takeuchi TB-007?
I purchased it with the engine not running, and the sellers story was it was traded for without a starter, and when the new starter was installed, it would not crank. It must have cranked for a little bit anyway. When I tore into it today there is part of a connecting rod sticking through the side of the block behind the starter. If you were putting the replacement starter on it you could not miss it.
It will still be a good deal if I can get a replacement engine cheap enough.
Also anyone have a repair/service/owners manual? I have a parts manual for it, but nothing else.
Thanks for any help.
Bubbagoat
Bubbagoat
