tag trailer behind truck
tuney443
Dutchess County,NY
excavating contractor
Hate to break it to you .....but..... 45,000#'s is not 25ton .... I think if my math is correct, that's 22.5 ton .... lol ..... just fun'n ..... unless a guy is totally crazy to pull a tridem empty, no tongue weight behind a 2500/3500 single tired (non-dually) p/u is an accident waiting for a place to happen ..... I have a single axle L-8000 tractor on air and I WOULD NOT pull that behind it because of the three axles trying to steer, it's NOT the weight, it's the tracking of the trailer..... but what do I know 3,500,000 miles with big rigs .....
tuney443 : I think you are baseing pulling 20k as gross combined weight and not dead weight pull safely ... if you take the 20k + 9,000lbs for the tare weight of the p/u thats 29k lbs ....., THAT's a retarded amount of weight to ask of a 3/4 ton p/u over a great distance legally/safely ...... I did pull my Trail-king T/A TKT40 empty behind my p/u a few years ago (empty) ... don't ask how I kept the air brakes released .... it was a 2mile tow .... AND NEVER NEVER AGAIN .... braking was not the issue but turning, now that was another story .... it wanted to pick up the rear of the p/u in the turn and shove it straight ahead .... THANK God for 4x4 engaged point the front wheels and GIVE IT S**T .... NEVER NEVER NEVER AGAIN .... stupid stupid stupid ...LOL ..... but what do I know
BUT as he now has settled the dipute here nickendall has finally returned with the info on the trailer, it's air-brake equiped and he's seeking a semi to tow it safely home .... BRAVO !
Your math is off.My 3500 is 7,200 lbs., trailer is 6,000 lbs.,app. weight of load on the trailer no more than say 6,000 lbs which now totals 19,200 lbs.Perfectly safe and legal.
CRAFT
100 M H,BC,Canada
30 yrs Owner/Operator
IF your p/u is 7,200 lbs (which i'm sure it is) that's a light weight p/u ....my 3500 dodge dually the way it sits in the drive way ... weighs 10,200 lbs, I carry a 100gal tidy tank full of diesel, in the box and have a 24k King-pin style fifth wheel hitch mounted full time as well ........... but you stated PULLING 20k not 6,000 lbs .... even at 7,200 lbs + 20,000 lbs that's even worse with barely any tongue weight that a commercial tag trailer has ..... a trailer that has a huge amount of forward tongue weight is what is needed, but that would only work in a gooseneck configuration, a bumper hitch tow and that weight (20k) is NOT legal anywhere even with an equalizer hitch w/swaybars ..... the heaviest class VI frame mounted hitch is only DOT rated at 10,000 lbs trailer weight, also the 2 5/16" balls for a class VI are ONLY rated at 10,000 lbs ...... only the balls for a gooseneck hitch are rated higher ......
Anyways, the talk was about a tri-axle commercial tag behind a p/u truck .... here and everywhere when you have a class-1 CDL it's our job to know our weights all of the time ...... COPS & DOT just have no sense of humor
DGODGR
S/W CO
I think there is some confusion here. IMO the OP said he wanted to haul an empty 25t tag trailer. The 25t is the payload. I have one of those trailers and it weighs 11,000# empty. 11,000# plus the weight of the tow vehicle equals the gross vehicle weight.
tuney443
Dutchess County,NY
No confusion--we're all on the same page.The problem is braking an air equipped trailer with no air on the horsey but the OP is now going to plan B so this is now moot.
tuney443
Dutchess County,NY
I most certainly do not have a light weight truck Craft.Mine is SRW--yours is DRW.A one ton designation is only for ID purposes these days.Proof is my 9900 lb. GVW.2700 lbs of cargo weight.
Once again,my trailer weighs 6K lbs. I NEVER said it weighs 20K lbs. You are confusing yourself from my statement that a 2011-2012 GM can pull a 20K lb. trailer.
A class VI receiver is rated at 9 ton, not 5 ton.My pintle hook/ball combo is rated at 8 ton.
I did get a chuckle out of your expense on that one.;) Hey we've all done those things that were absent minded and 1/2 through the "operation" you say "God please let me get to where I am going and I will never do that again".:D
CRAFT
100 M H,BC,Canada
You liked that huh ! ..... I thought a few like yourself would appreciate that .... kinda a bin there done that ......... it's amazing what a guy can do at 2:00am living in the boonies, when you have to get something done in a panic ...... had to get that trailer to a site not far from home and load the 312 on it and have it ready to pick-up for a guy with a tandem dump later that morning .... that was the day after my 475hp twin turbo Cummins blew up ...... but what I won't tell you is how it got moved from there to another 1/2 mile away with the excavator on board behind the 'ol Ford .... and that it's totally amazing what you can pull in low range locked up .... them tires were justa chirp'n pull'n up that grade .... and I won't tell you that the generator was in the box keep'n the air compressor runn'n and the air hose was coming thru the sliding back window to the front seat with an air valve on the seat ........... but I refuse to tell you that ....OK .......LOL ..... AND WE LIVED TO TELL THE STORY ! ..... and put another chapter in the book of dumb things i've done in my life ..... Cheers
DGODGR
S/W CO
Imagine the tongue load being transfered to the pick up on that trip. You should tell Ford about that. Maybe they'll make a commercial out of it.
CRAFT
100 M H,BC,Canada
That was the easy part of it, the trailer being a tilt deck w/hyd cyl's control the drop rate as the deck comes down .... as you hit the balance point it came down slowly until frame contact ... then I just inched the ex forward until the trucks suspension came down what looked like 6" then I stopped ... the pick-up was equiped with air bags that I over inflated before loading ... it sat perfectly level with just the right amount of traction ..... it was a slow move but we got the job done and no bridges were burnt the next day
That was once and never again ..... that's when I bought the L 8000 tractor as a back-up plan
That's the way I would have done it...:Cowboy:rolleyes:
Kids don't try this at home.:professor
