Tag-a- long Trailer ?
Nac
NJ
Construction
I end up getting a 25 ton BWS will pick it up saterday and post some pics when I have a chance.
Nac
NJ
Construction
Well i picked up the new BWS 25 ton tag a long yesterday. All ready made two moves with moved my John Deere 160 Clc and a Lull 1044B I just aquried from a customer that has to give me some money. I was a breeze to load and unload. Forgot to take pics but I will
BIGDAN315
Newark, NY
Self employed in the excavating buis and have been
Are you not running overloaded, with a 160 class machine on a 20-ton trailer? Our Case CX-160 is 17.5 metric tonnes fully loaded, adding the weight of the trailer puts us at around 21 metric tonnes in total. That does not even include carrying a 3000# class hammer, extra bucket, etc.
Sounds like he might be pushing it hu ? Sometimes it's all on where you position the machine on the trailer. What I mean is how much weight is on the truck hitch and how much is on the trailer wheels ? I guess you would have to scale it to be sure....:my2c
Nac
NJ
Construction
Here is pic of the new trailer sitting in the yard
Nice trailer.:notworthy
My next tag will definetely be a tri. Is that a tilt?
Nac
NJ
Construction
Here are 2 pics of the trailer loaded
Nac
NJ
Construction
here are more
NateV
Pittsburgh PA
Excavating
Looks good!
Question for you, does the license plate hit the ground when the trailer is tilted? It seems like all trailer mfg put the plate in a place that will drag the ground if you get into a dip.
Nac
NJ
Construction
No the plate does not hit there is a steel pad in the center that sit on the ground when you tilt the trailer.
Cat420
Pine Bush Ny
Construction, small engine and machine shop work
Welcome to HEF trailerman.
Unfortunately I must suggest reading this entire thread before recommending CAM anything!
Nac
NJ
Construction
here are some more pics.
Countryboy
Georgia
Load Out Tech. / Heavy Equipment Operator / Locomo
Welcome to Heavy Equipment Forums trailerman! :drinkup
Nac
NJ
Construction
I had problems with it and yet to get it redisegned and up and running
AtlasRob
West Sussex UK
owner operator
Neat trailer Nac. Only one query.
The first set of pics you posted there was no bin on the truck. I would be a little concerned about the tail wagging the dog :eek: If the truck is toooo light, eg, no bin ! Or do you put a bit of weight in the bin when moving?
Nac
NJ
Construction
I normally run it with out a box the truck is 30,800 lbs with out a box so I have no problem. I need the box on the job I was going on thats why it was loaded.
SunServicesLLC
MD/VA
Hey Nac
Wondering how the q/c grapple is working for you? After running my 200's, i would love to get the heavy thumb off the tippy 160 while loading out dirt after the house is long gone.
Brian
