Deas Plant
Blind Spots.
Hi, Folks.
Now how did we get to 'blind spots' from Sum Foters??????????
O.K., so we're here at 'blind spots'. I have been operating for a LONG time on a LOT of different machine and I have yet to operate a machine that was made completely of clear glass. CountryBoy, you got it dead right the first time - if you can't see there, it's a blind spot.
O.K., how do we operate these travelling blind spots without wiping out everything within shooting distance of us? Well, memory and observation are the keys. Observe where the obstacles are, memorise those locations and work around them. The better your powers of observation and your memory, the better you are likely to be at missing the obstacles.
Quote: "Now blade visability is another thing on some dozers, older oval D8's
and D9's are the best for that as is a D375 Komatsu." (Dozer 575.)
On the D8H's and K's, you could see the bottom of the back of the blade above the tracks over the front idler. GOOD blade visibility!!!!!!! I loved it.
On the D9G's and H's, the closest part of the back of the blade to the ground that you could see over the front of the tracks was about 10" - 250mm - ABOVE the ground. GOOD blade visibility?????????????????????????????? But I still managed to grade haul roads with them. Not to a grader finish, but certainly good enough to run dumpers and scrapers reasonably quickly on.
I have never run a D375 'Kummagutsa', so I'm not qualified to comment on them but I have run a couple of D155's and an older D355. I liked the blade visibility on the 155's and I was cutting road boxes with the 355 to around 1"-2" above finished so the blade visibility can't have been too bad there either. I ran a D455A with a U-blade for a few hours too and didn't have any trouble cleaning up with that either.
Personally, I DO watch the corners of my blade, especially when doing fine work - and that includes cutting to +/- 1/2" with laser monitoring on a Cat D5B, which I do a bit of again these days. When bulk pushing, I tend to watch the movement of the dirt above the top of the blade to see how much I am cutting, if any. At the same time, I am also aware of where the cutting edge is and what it is doing.
When I am shaping a job, I tend to largely ignore what the actual tractor is doing and concentrate on keeping the cutting edge where I want it to achieve the desired result. This may seem a little contradictory (Have I read something about contradictions in the thread before?) but when you have blade tilt, you can get your tractor in some awkward positions and still keep your cutting edge where you want it, so long as you know the limitations of your machine.
LDK, 'blind spot' is perfectly acceptable if that is what you want to call it, especially if you believe that it IS a blind spot.
Dozer 575, unless an operator is 20 feet tall and made of rubber and there is NO cab to stop him getting his eyes into the appropriate positions to see EVERYWHERE around his machine, or unless he/she has X/ray vision, there ARE blind spots with EVERY machine. The trick is to learn to work around the blindness of those spots so that you don't do any damage and only cut where cut is needed or fill where fill is needed.
Happy debating, gentlemen.
Hi, Folks.
