Chewie2105
Hi posted this on the roller section but as not a paving roller might have been missed. wanted to reach out again and see if anyone may have any insight, prevailing thought is possibly a hydraulic issue causing the motor to be turned into a pump and then resist not free spin.
Hey anyone familiar with older stone rollers? or have any thoughts
roller works great but keeps stripping out the coupler for the vibration on the drum. seeing as stone has gone belly up had a local company rebuild it, worked well for a while (rental yard so time is relative)
stripped out again, company warrantied the coupler, try again lasts about same time (50 ish hours) and failed again, this time they replaced the small spline coupler and motor with a keyway set up
worked well for a year but last rental it stripped out the keyway out.
pulling the coupler means pulling the drum so is getting very old
eccentric spins freely by hand, bearings all checked out, oil level is correct and clean, drained and refilled each time
popular little machine and hard to replace but consistently causing issues, also has a odd chattering in the wheel drive motor area when switching from forwards to reverse at high speeds, checked out the unit and can not find a issue
