Steve is right!
coopers -- if you aren't planning on using it all the time, Steve is right about the 390, it's a great mid-grade saw that doesn't break the bank -- same body & weight as the 290 and 310, but more power.
Buying extra bars & chains will let you maximize your saw's potential, I find that 4"/HP with full complement 3/8" chain is optimal for me if the saw is for felling and bucking -- if you need to go longer, you can go with skip chain so there are fewer cutting teeth in the wood at any point. I find that most folks dump the tip of the bar into the ground if the bar is much over 20" so I'd stay away from only having a 24" bar. Also, with an extra bar & chain, you don't need an extra saw to extract yourself when you invariably pinch... and it'll always happen when you don't have time or help. For the bar you will use the most, have 3 or 4 chains so if a couple are off getting sharpened you aren't hosed... for the spare/longer/rescue bar, 2 chains is enough. If you are thinking about a pair of saws, make sure they share the same bar mount!
Stihl's numbering system used to be "0xy" where if "y" was even, it is a pro series... now they unified their entire numbering system so it became "MSxyz" -- it still works out, for the most part, that if "y" is even, it is in the pro series and "z" is the revision level. I like rim sprockets for the pro saws, but for light use, spur sprockets are good enough. On pro saws, I like the wide nose ES bars but any of the bars will work well. If you are comfortable running a saw, get chain without the "comfort" links, it is easier to sharpen and will generally run better. Super chain cuts better in most wood, but is harder to keep sharp and goes downhill quick if you round off a point -- Micro chain doesn't cut quite as well but lasts better, especially if there is dirt on (or in) the logs. Elastostart is nice, but can be added later when you break the pull cord. Tool-less tensioning is annoying, to me, because it is hard to keep clean and doesn't let you flip the bar, easily, when you change chains.
As you can tell, I love my Stihls... I fell with an 066 w/ 24" or 32" or a 440 w/24". For light limbing I use older 023/025's w/ 16" bars. Bucking firewood is 036/361 w/16" or 440 w/20" territory. One of these days, some of those 025's will die and I'll move up to 260's so the bar mounts are all common. I also maintain saws and chains for friends, so I play with several more 025/250's, 270, 039, 046 and a couple oldies like an 009 and an 031.
Good luck and have a Happy New Year, everyone!
